-_dwh_-
Apr 01, 2012Explorer
Atlee wrote:
Is there larger extended run gasoline tank available that will work on twin Champion 2000 generators?
I know there is a Honda one available. For that matter, would the Honda extended run gas tank fit the Champion 2000?
The reason that extended run tanks work on the Honda, is because it has a fuel pump.
So you run a line into the top of the fuel cap from an external tank, and the vacuum created by the fuel pump sucks fuel in from the external tank.
Setting up an external tank for a generator which uses gravity feed is a whole other ball game.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
