bruno1138
Aug 13, 2012Explorer
navybanker wrote:
What type plug fits the outlet on the left side of the parallel kit? I have used the 30amp RV outlet on the right but haven't used the left one.
I use one of these - converts the twist 30 amp to 2 x 20 amp standard 120 volt receptacles. One problem though, the twist lock is not tight and I have to tape it into the locked position to not be loose. Has anyone else had this problem using the left hand side twist lock receptacle on the parallel kit?
http://www.amazon.com/Coleman-Cable-Generator-Adapter-Splitter/dp/B000IUL9P2/ref=sr_1_2?s=hi&ie=UTF8&qid=1344876818&sr=1-2&keywords=champion+adapter
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
