time2roll
Dec 04, 2020Nomad
TempleinCanada wrote:Yes you can connect all batteries without issue even on a regular basis.
Here is my question: If one of my battery banks becomes low in available amp hours could I connect the 2 battery banks together (with a manual switch)to equalize them (I know it is not ideal, but would be for an emergency only)
My main concern is that the solar controller sees the 2 battery banks as separate, what will happen when it sees both of them together???
Multiple charging sources is not an issue either. You can have both solar, converter, vehicle alternator, and a portable charger all charging at the same time without issue.
