ThruTraffic
Jan 05, 2023Explorer
bob_nestor wrote:
I once had a similar problem but I see you stated in your original post that:
"- Checked connections at transfer switch, socket for shore power, junction where old EMS used to be, mains in RV breaker panel. Checked neutrals, grounds and feeds. All tight."
... so I'm not sure if this helps any, but...
The source of my problem was in the main RV breaker panel. Even though all the connections were tight I discovered that someone (at the factory) had cross threaded the screw holding the neutral line in the box. (Things worked for for a few years, then I had power issues.) The screw was tight but hadn't been holding the wire very well and over time the connection degraded with a patina build-up similar to what happens in the contacts in the transfer switch. I had to remove and replace the small bus bar the neutral was attached to and that fixed my problem.
I pulled a new feed from the t-switch to the breaker panel so no patina on the main feed. I didn't replace the neutral buss but I did re-seat all the neutral and ground terminals and even bonded the neutral and ground buses and that made no difference. (bonding removed now).
The only thing I have not replaced is the breaker panel. :-) I really can't see how that would fix anything but at this point I'm not discounting divine interference. LOL
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
