dmjaway
Mar 15, 2018Explorer
dougrainer wrote:
All you have to do, is remove the NON pressure input fitting on the pump from the water tank. With City Water connected, you will know if the pump is the problem. Water will flow out of the disconnected threaded fitting on the pump. Doug
Yes, that would be a good check if the problem was consistent, however, it is not a continuous problem and besides, with the FR SS 3050S it is no small chore.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
