urbex
Jun 22, 2023Explorer
If your load is close to the eating of the breaker, such as pulling 14 amps through a 15 amp breaker, it could get a bit warm
However, the much more common reason this happens is because people use the breaker as a switch, which it isn't intended to do. Repeated cycling of the breaker causes it to wear out pretty quick, which will increase internal resistance, which causes heat and premature tripping.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
