Old-Biscuit wrote:
Tom1949 wrote:
I know that this may sound oddball; but, it's helped others.
Check the outside shower head and make sure it is not in the "closed" position with the faucet left in the "on" position. It may be diverting enough hot water to effect your shower inside.
OP gets hot from electric 1st heat cycle then NO more heating and gets hot from propane with repeated heating cycles.
Issue is with electric side of WH.
Shower ----luke warm regardless of heating method
OP stated, "The condition it is showing is, when I get to a campsite and after I make all my shore connections I turn on the water heater for electric heating. In an hour or so I have hot water, so far so good. In the morning, the water is luke-warm."
My suggestion could still apply. I've seen it apply, in exactly that manner. The idea is there, if (s)he wants to try it; and, it certainly doesn't hurt me if (s)he doesn't want to try it.
Have a wonderful day...
