dougrainer wrote:
The most common cause of this type problem is, you have your City Water tank fill valve OPEN. This will cause the pump to continually recycle the water. I also assume it will turn OFF when requested to do so? From the Pump On/Off switch?. Now, if you are connected to City Water and that valve is left open, your fresh tank will overflow. You are new to the forum. ALWAYS, list Year/Make/Model/Chassis of RV when posting. Or put this info in your profile. Doug
Liste the info I could in the profile. Some of their selections are outdated and don’t have years past 2020
