theoldwizard1
Sep 21, 2023Explorer II
rvshrinker wrote:
3. How do I prevent this kind of corrosion in the future?
The BEST solution, is replace the wire, end-to-end, with marine grade, pre-tinned wire of the same size. If end-to-end replacement, cut the wire about 2' away from the the battery. Splice in the marine grade wire using an uninsulated splice and use marine/dual wall heat shrink tubing to cover it.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
