grampaBubby
Aug 29, 2013Explorer
You can test the output by connecting the panel to a battery who's in need of a charge. Place the panel in optimal sun exposure. Using a multi-meter one can test the "load" being placed on the panel. The reading will never exceed the panels max-out rating but until either the sun goes down or the battery reaches a full charge the output load reading from the panel should be just at or just below it's max-out rating.
I won't explain how to use a multimeter but I will say that most offer settings for reading the line load. The directions that come with the meter will give you the proper settings.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
