lc0338
Jun 27, 2013Explorer
You might be right about not being a good inverter. I have a couple of cheap ones that plug into the cigarette lighter (400a max) and use them periodically. They have lasted longer than I expected. Well, with a portable system there is alway's the possibility of theft / vandalism. This is my first attempt so I am kinda "prototyping" the system I need. If it looks ok for long term the next time I buy an inverter I may pick for better quality. Like car's the expensive ones get stolen so maybe they will just pass up my stuff.
As far as 12volt power - Of course each of these RV's have their own battery. The gooseneck has 2ea 12 volt batteries and the bumper pull has 1ea 12 volt battery. When I plug the extension cord in the "converters" on the RV's will keep the on-board batteries charged plus supply 12volts for the RV's. I didn't understand the "you need an lc (inverter/converter) to charge" comment.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
