lc0338
Jun 27, 2013Explorer
Thanks for all the input. I have not pulled the trigger on anything yet. I have read a lot of stuff about people starting off small (12volt) and soon realize they needed to step up. That is the reason I was kinda starting off bigger. I have dry camped a lot but always run the generator when needed. I'm just trying to minimize having parts I have to throw in the corner to get rigged up differently. And it may be right that a "solar cart" may be a little out there. At minimum if I have a cart made that I can load with my bale bed I can leave it on the truck and park my truck in the sun. I am planning to full time RV for awhile, until the wife gets homesick, so I want to live as cheaply as possible. I was looking at the solar panels up to 250 watt and they said for 24 volt I needed 2 panels and reason I went with 2 panels for my initial setup. In reality I guess I could initially set up the system 12volt and only purchase 1 250 watt panel then switch it over to 24 volt, if needed, and only have to purchase the other panel and rewire my batteries from 12 to 24 volt.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
