SteveAE
Jun 28, 2013Explorer
lc0338,
So as I understand it, what you are looking to build is essentially a "solar generator". The device will have solar panels, a charger, batteries, and a inverter. And the 120 VAC output of the "solar generator" will be connected to the converter/charger(s) of your other trailer(s) to charge their batteries. Is this correct?
If this is so, here are my thoughts:
- While not the way most folks would build a RV solar system, there is nothing wrong with creative thinking and looking at possibilities like this.
- Many items in your RV's use 12 VDC. You will loose a lot of power though the inefficiencies of both the inverter and the converter when running your 12 volt items.
- If you only have a stock converter in your RV, the charging of your RV batteries will be very prolonged, such to the point that the sun will likely have set long before your batteries get charged.
- A small generator would be less expensive, lighter and easier to move, and will do a better job of running higher power line voltage appliances (especially those with high initial startup current) than a "solar generator" (note that I am a solar proponent when it makes sense and I have yet to use my generator for camping).
- You will have the expense and labor involved with maintaining, and replacing, another set of batteries.
- Another approach might be to install a solar charge controller in each RV and then just take portable solar panels along.
Good luck with your project,
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
