2oldman
Jun 28, 2013Explorer II
lc0338 wrote:You bet!
. Could you describe your system in as much detail as possible and why you changed over?
A lot of your questions can be answered here:
24v inverter install
System schematic:
Why did I do this? Many reasons actually
a) I was lugging around and maintaining 6 GC batteries. Heavy stuff.
b) I wanted to go back to 4 batteries, but I remembered that 4 @ 12v weren't able to handle big draws very well. I reasoned that higher voltage would cut the amps in half, maybe being easier on the system. For sure it cuts down on the heat at the wires, connections and batteries.
c) I have a high-end Outback controller which can handle high-voltage PV arrays and up to 60v battery banks.
d) just for the heck of it! Nobody else was doing it, and I wanted to see if my ideas were valid. Also my Prosine blew up!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
