lc0338
Jun 29, 2013Explorer
2oldman wrote:lc0338 wrote:I meant an 18a charge rate. Over 5 hours that's 5*18 AH.
. 2oldman say's 3ea 100 watt panels will give 18a in 5 hours.
90ah sounds a lot better but maybe short of my wag of what I thought I would need. Will have 4ea 6 volt t-105 and predicted draining them to 10% overnight. If same set-up and only drained to 50% overnight I would need a little over 200 ah?
Still looking for thoughts on wet cell or agm. Since I may be moving the batteries around a lot there was concern if not kept in level configuration I could damage batteries and hence the suggestion to use AGM batteries.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
