lc0338
Jun 29, 2013Explorer
BFL13 wrote:
A 100w panel costs about $100. Are you really going to spend $600 on a controller for $300 worth of panels? Sigh. You can run 300w with a 30amp PWM controller that costs maybe $50.
It is not sounding very worthwhile. Chose 100w panel to be able to mount 3ea permenant on "rover". If set-up is portable can use larger panels. Yes, MPPT would be more expensive but in 3-4 years if my solar set-up needs do change that is one piece of equipment that I should never have to toss in the corner. Who knows if I will always be able or want to locate the controller close to the battery bank. Flexibility is still much desired.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
