BFL13
Oct 06, 2020Explorer II
Should be two wires coming in from the furnace to the Tstat. Jumper them and it should fire up after the usual delay. The Tstat just jumpers those wires when set to want heat.
I got a digital Tstat that is for heat only. Put one wire to R and the other to W and you are good to go.
The two wires are just the one wire cut there so it can be switched.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
