time2roll
Jun 18, 2018Nomad
Good to go, no issues. Yes you can use a portable charger at the same time if you think it is needed. Not sure I would run the portable in jump-start mode. Max normal should be fine.
If you really find that you want more voltage on the battery... get the PD9260-14.8 at bestconverter.com
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
