Gjac
Jun 19, 2018Explorer III
bgrasspkr wrote:I dry camp 95% of the time and do this quite often. I charge at 40 amps and connect the charger up front about 1 ft from the 2 GC batteries using a 40 amp B&D charger. The charger also equalizes and desulfates. I replaced the 2 12 v batteries when I bought it with 2 Trojan 105's, they lasted 4 years the 2 Sam's club batteries replaced the 105's 10 years ago and still going strong which I attribute to better maintenance using the equalizing function of the charger. You can still use your exiting converter/charger (and not change any wiring) once you get home to fully charge the batteries if it has a constant charge feature or maintenance mode.
If I'm not getting enough voltage during bulk mode due to wiring issues, can I use my car smart charger on jump start mode ( 75 amps)for a little while? Read only a couple posts about this. Not sure it is safe or practical
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
