3_tons
Jun 20, 2018Explorer III
SoundGuy wrote:donn0128 wrote:
Why do you want to cut your available power by a third? Two 6V golf cart batteries will be barely more than one 12V.
What in the world are you talking about? :h A pair of T-105s in series will be 20 HR rated around 220 Amps, half of which is usable at a 50% depletion rate, a pair of G31 12 volt batteries wired in parallel will be similarly rated.
Not so...GC’s can make routine excursions below 50% DOD (depth of discharge) without damage, thus, the ‘usable capacity’ is typically greater yet with the same or similar footprint...
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
