anon125's avatar
anon125
rear camera monitor
in our old 2006 sunova the monitor is still cathode ray tube (CRT)
always worked before. today after sitting for a year it showed nothing. vehicle has about 20K miles on it.
pushing on/off got some light flashing on the tube.
what does a new modern one cost? maybe it is the camera of course.
as everything is Chinese made junk is there a least bad model?
voyage observation system VOM-7SN
thanks all
  • Before you start replacing parts, check to see if the connection came loose on the back of the monitor. From what I understand it's quite common for the manufacturers to "forget" to put on a clip that prevents the wire from working itself loose on the Voyager systems.
    Doug
  • IF we have to replace the old monitor...
    it hangs from the ceiling.
    do modern ones have that feature? of course it is where the wires are.
    thanks
    thanks
    I mounted mine from the ceiling which puts the monitor upside down but there is a "flip" setting that inverts the picture. I think most do that but I'd verify to be sure.
  • Were you able to find a cure to the ailing monitor system?
    Doug
  • I saw nothing obviously wrong - it goes to the tech next wwek.
    thanks
  • lc0338 wrote:
    replacement kit
    okay we have the kit.
    does anyone have a picture of it replacing our old monitor that hangs from the ceiling?
    I wonder where the aluminum bracket is supposed to go.
    thanks all
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
