They will sag over time
Airbags will protect them to a degree
Re-Arch doesn't last as long as Re-Place
It's possible to add a leaf (leif?) to restore height and capacity.
Questions: Do you un-load your truck when stopping overnight, when you don't have to un-hitch? It helps to take that overnight static load off.
And, what is the Pin Weight of your Fiver? I ask because I know pin weight improves stability, but it seems some have more than they need. I notice when camping that some similar-sized fivers put a lot more weight down onto similar trucks than others do.
We had sagging rear springs on an old Class C. Went to a spring shop and talked options:
1. Replace with new springs, too expensive.
2. Re-arch the OEM springs, shop said it wouldn't hold long enough to be helpful
3. Add a "repair leaf" to the existing springs, this is what we did.
Repair Leaf is nothing but a length of spring material. Thickness according to how much lift wanted. Width to match existing leaves. Needs to be cut to length and punched/drilled for center bolt.
Since I bought the parts (repair leaves, new center bolts, new axle U-bolts) and installed myself, I didn't have the benefit of their experience. This may not happen to you, but in our case, the rear ended up slightly higher than level. That cut down on tail-dragging which was nice, but it also meant we had to block the front up about 2" to be level on a level campsite. Pickup truck doesn't have that issue, and you might be happy starting out a little high.
