Old-Biscuit
May 16, 2013Explorer III
PCronin68 wrote:Old-Biscuit wrote:
Could be jammed in closed position....have your tried to manually crank down and then use electric?
I think that’s exactly what happened...once I "jiggled" the legs from both sides it worked. How do I manually crank them down. I don’t see anywhere to attach the manual crank. Do I take the black rubber cover of the end of the motor?
My manual crank is a hex head bolt on opposite side vs on motor side.
You need to check how your stabilizers are configured.....and see if you have info in a manual.
But motor driven stabilizers should have a manual means of operating them.
