CA_Traveler
May 05, 2013Explorer III
Just because the lights do not turn off with the aux switch does not mean they are on the house battery. Disconnect the chassis batteries - what is the light status?
The aux switch should turn off loads like lights but not everything. Would you want it to turn off the refer for example? That's the function of the battery disconnect switch which you may/may not have.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
