- Monaco_MontclaiExplorerI have had good results from a garden hose, on a gas. Rad, and not to hurt anything else.imho, anything any stronger(on the outside) is too strong.imho and now it's all --happy-camping
- aihchris107ExplorerThank you for the replies.I am going to clean the units this weekend
- oldmattbExplorerI don't know how your coach is set up. On our coach, I removed six screws, and the louvered cover lifted off to fully expose the coolers.
Matt B - oldmattbExplorerI cleaned mine last week, doing almost exactly what Wolfe said above. I used regular Simple Green and AC condenser cleaner. I rinsed until the debris stopped, and then rinsed until there was no trace of foaming when the water hit the coils. (Probably a good ten to fifteen minutes of flushing.) I used a water hose with a nozzle, but no pressure washer.
A decent pressure washer could destroy a radiator's fragile fins in a second.
Matt B - islandvagabondsExplorerX2 on Wolfe's comments.
- wolfe10ExplorerBe VERY VERY careful using a power washer-- very easy to bend the fins.
Please confirm, but I believe your cooling system is STACKED (vs sandwiched).
So it is only a single layer thick (CAC usually on top of radiator).
Since I believe your OE cooling package is Aluminum, you need an aluminum friendly detergent. Best is probably Simple Green EXTREME-- designed for cleaning aluminum airplanes.
Since it is a single layer thick, you can do most of the cleaning from the back (back of coach). With radiator cool or almost cool, wet down the metal (garden hose with regular garden nozzle). Use a spray bottle to apply detergent. Let it sit for a few minutes, but NOT long enough to dry out. Systematically rinse down from the top with the hose nozzle. Repeat until nothing dirty comes out.
Probably wouldn't hurt to put plastic bags over things in the engine room you don't want wet, like the alternator. - chipperExplorerBe careful about using too much water pressure & flattening out the fins, (BTDT).
- tandkjExplorerThe only thing I can remember reading about this was using a power washer and spraying thru from the outside. If you need the Monaco customer hotline number to give them a call leave me a message.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
