BFL13
Mar 30, 2021Explorer II
The Hopkins uses the clearance light screws. You could invent something to mount yours that does the same and use some goop as required for water-proofing.
https://hopkinstowingsolutions.com/products/towing-cameras/50050.html
I mounted mine on a piece of wood and prop it up in the back window. This way I can switch it back and forth between the Class C and the TC whichever RV we are using. The display is your "device" so that is portable too. I put the device (an older small size iPad) on the rear view mirror with elastic bands.
