MrWizard
Apr 02, 2019Moderator
did it do this connected but not turned on
or only when running the shave ice motor ?
can you open the cover and look to see what is leaking, burnt etc..
filter caps, just require removing and replacing, some soldering ?
FET's etc.. are much the same but more 'touchy' in getting it right
i think you could handle the filter capacitors
hot cables and smoke , seem to indicate some shorted parts, in the power output section
but you don't know until you look
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
