CJW8
Nov 23, 2015Explorer
What else doesn't work when the breaker trips? Rec/con probably means either receptacle and converter or receptacle for the converter. Since your heater seems to trip it, it probably means receptacles and converter. If your converter is charging your batteries and the heater is on at the same time, it is probably over 15 amps and trips the breaker.
I don't know your RV but if it has an enclosed underbelly (arctic package or something similar)you'll want to allow your furnace to carry the heating chores when the temperature is below freezing because it probably provides some heat to the underbelly where your tanks are located.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
