MrWizard
Nov 23, 2015Moderator
nothing has changed expect the tripping breaker
sounds like a failing battery or failing converter
battery is cheaper and easier to replace than converter
lets hope its the battery
you will need to unplug from shore power while removing the battery
besure to take a picture of the wiring with cellphone or camera, before disconnecting the wires, wrap the wires in tape to prevent shorting problems
and you can plug back into shore power, while the battery is being checked/tested
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
