j-d
Nov 24, 2015Explorer II
CarolineGates wrote:
Member from Sunny Florida suggested to leave the MAIN ON, every branch circuit OFF and then power up one branch at a time so map out which outlets are powered by each breaker....
By "branch circuit" do you mean turn off the switches for a/c, GFI, hot water, micro? Just leave main on, then use the tester/I will try a night lite.
Exactly! You got it! The idea is to test one circuit at a time and see which outlets each one feeds. You may find one branch/breaker/circuit is all outlets/receptacles on one end or one side of your Cougar. That way, you can be sure to plug high-wattage stuff into separate CIRCUITS, not just separate Outlets in the same Circuit.
I'd sure love to see a picture of your breaker box and it's labeling as to what they say feeds what.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
