westend
Nov 24, 2015Explorer
The method to use to diagnose your problem is "Isolation". You want to break it down in easily observed pieces.
Also, answer some specific questions that are asked here. Do both heaters turn off when the breaker trips? The answer to that will isolate the problem to a single branch circuit.
Removing the battery cable from a battery terminal will isolate the problem to the converter circuit if all works in that situation.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
