Charlie_D_
Nov 24, 2015Explorer
j-d wrote:CarolineGates wrote:
Member from Sunny Florida suggested to leave the MAIN ON, every branch circuit OFF and then power up one branch at a time so map out which outlets are powered by each breaker....
By "branch circuit" do you mean turn off the switches for a/c, GFI, hot water, micro? Just leave main on, then use the tester/I will try a night lite.
Exactly! You got it! The idea is to test one circuit at a time and see which outlets each one feeds. You may find one branch/breaker/circuit is all outlets/receptacles on one end or one side of your Cougar. That way, you can be sure to plug high-wattage stuff into separate CIRCUITS, not just separate Outlets in the same Circuit.
I'd sure love to see a picture of your breaker box and it's labeling as to what they say feeds what.
No electrician but the OP second sentence makes no sense to me. What does make sense is to turn off all breakers then turn 1 breaker on at a time. Check every outlet to determine what each breaker energizes.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
