wa8yxm
Dec 01, 2015Explorer III
You are correct that REC/CON is Recepticals and Converter.
Depending on your converter it can easily draw up to 10 amps (Take the last two digits of the model number and divide by 10, write that number down, now divide by 5 write that number down, add the two together and that's the peak draw).
Add to that whatever is plugged in. Heaters. Fans. Hair Dryers. Deep Fryer. And you have the click of darkness.
The solution on the converter is to let the battery charge, as the battery charges the needs go down down down to the point where the converter with FULLY charge batteries is in the single amp range.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
