path1's avatar
path1
Recommendations for volt meter
I have several harbor freight volt meters. The price was right for them, buy something and they give you one for free, with an ad sometimes. They have worked fine for me in the past, but for simple things.
Currently trying to solve auto elec problem with very slow pedal response. I have to measure something to see if between 0.01 to 0.03 AC volts. Thinking I need something better than cheapies. The choices for a new meter are somewhat endless and many have capabilities that are much over my head. So not sure what to get.
Would like recommendations for better volt meter. Lets say under $100.00 and has good instructions.
Thanks for any input.
  • path1 wrote:
    Harvard wrote:
    Maybe my meter could be zeroed but I do not know how..... I paid over CDN $200 for this puppy so I am not impressed when I see the older Fluke model do 0.00 in the video.
    Thanks. My reason for testing in first place is to make sure voltage is within spec's. I understand over voltage shorts life span of ECM. And they're not cheap.
    Thanks again
    Yes, I see that you are trying to verify the AC ripple riding on the DC Volts.
    "Most electronics are killed by high AC noise. 0.4 AC volts is a automatic fail... Normal good alternator is 0.01 to 0.03 AC volts. Marginal is 0.05 AC volts. Then a complete fail is 0.1 and above
    Thanks again
  • Maybe my meter could be zeroed but I do not know how..... I paid over CDN $200 for this puppy so I am not impressed when I see the older Fluke model do 0.00 in the video.
  • Harvard wrote:
    Your target voltage (0.01 to 0.03 VAC) is not at all practical outside of a very sophisticated lab environment. IMO.
    I have a fairly expensive Fluke 115 True RMS Multimeter which is auto ranging. On the AC Volts range with the probes shorted together the meter reads 0.022 VAC when ideally it should read 0.00 VAC.
    Maybe your right. Here is test I'm trying
    https://www.youtube.com/watch?v=r-z-_7t_Zco
  • Your target voltage (0.01 to 0.03 VAC) is not at all practical outside of a very sophisticated lab environment. IMO.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
