loggenrock
Sep 15, 2016Explorer
Hi Don - been running TST system for almost 10 years, close to 100k miles. Dependable, great customer service, has saved me 3 times so far. As for cold weather... I pull the monitors off the stems when I park it for the winter (saves the batteries - no pressure turns them off...). Can't see any reason they wouldn't work simply due to cold - give TST a call - odds are they can answer that for you. Their system was intended for over-the-road trucks, not RV's, so those guys don't park their rigs for the winter. The one winter issue I could see is the monitors do cause the stems to extend a bit further. Not an issue on my rear duals, recessed into the dish, but on the fronts I could see where they may attract snow/slush/ice, or snag if you are driving in deep snow, etc. They do recommend metal valve stems - I had a tire shop just install regular brass truck stems up front, but went with specialty dually valve stems from Borg to mount them on the rears. ST
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
