BFL13
Dec 09, 2019Explorer II
Powertour wrote:crcr wrote:
Are you wanting to shut off power from the solar panels to the controller? If yes, why? If your batteries are full and your solar controller is a good one and is working correctly, it will never put more power into the batteries than what they need. That's what the controller is for.
Correct. There are times when I'm going to need to service (clean terminals, top off water etc) or change out the batteries & at times like that I don't want everything 'hot'.
Missing is the requirement for some controllers (Morningstar's for example) to not be left with the array connected and the battery not. Must follow sequence! Hence the need for a switch on the array side.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
