pianotuna
Dec 11, 2019Nomad III
BFL13,
I'd use a bi directional switch with arc protection both ways.
BFL13 wrote:
On polarity "direction" I don't see the way that is marked on a switch, so how to get it right way around if on the battery neg wire or pos wire? Would want an arrow toward the battery (or solar panel) positive post in the States (or negative post in Canada?)
With the solar controller in the middle and the array as the "current source", which way is "positive"? You have the battery circuit direction and the array circuit direction, but the PWM controller passes the battery voltage to the array. How can it do that if they are in opposite directions?
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
