wa8yxm
May 08, 2018Explorer III
Fault light. Means the control board did not sense the flame.
I have an Atwood, when it was new I often had to try 3 or 5 times before it would work, after that it kept working.. or if I was able to heat it up electrically it will work after that.. Finally the control board failed I've not had that problem since.
But that is only one cause.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
