BoonHauler
Jun 10, 2016Explorer
GordonThree wrote:BoonHauler wrote:
Anyone using a thermostatically controlled switch to turn the fan/s on and off?
Any links? How are you controlling the fans/s?
There are simple 12v thermostat modules on ebay and ama zon ... the poster using the fixed thermostatic cut-out switch found a great solution too, can't beat that for simplicity.
I'll be using one of these, a multi purpose module I designed myself
It's a WiFi connected DC switch, that also supports data collection. So I can monitor temperatures, adjust the on/off settings, using my cell phone. It has two outputs, so in theory I could use number one on fans for summer cooling, and number two on a relay and 40 watt light bulb for winter heating.
Thanks for posting.
So with your set-up do you have an upper and lower limit (set point or do you have a simple on above set point, off below set point?
I'd have to think the later would be susceptible to cycling.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
