BoonHauler
Jun 11, 2016Explorer
GordonThree wrote:BoonHauler wrote:
So with your set-up do you have an upper and lower limit (set point or do you have a simple on above set point, off below set point?
I'd have to think the later would be susceptible to cycling.
Yes, two set points, one for on, one for off.
I think most thermostatic devices, electronic or mechanical will have some degree of hysteresis, to avoid too-frequent cycling. Where it's adjustable or not is what adds cost :)
One limitation of my little module is it lacks speed control (it was really designed to control other loads). So the fans are full on or full off. I'll try to include that ability in the next revision.
Gordon:
Where did you get your controller? .... No speed control is not an issue for me.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
