TechBill
Jul 14, 2014Explorer
Refer unit in pop up camper
The refer in pop up camper haven't been in used for over 10 years and the access panel had been missing all those year so the heating element been exposed to outdoor elements.
Today I took the refer out and use a blow gun to blow all the rat nests and leaves out of it then gave it a good scrubbing inside with borax and dawn.
I hooked it up to a 12V battery running on a charger. The heating element seem to be heating up getting hot but I am smelling some odors from it. I am hoping the odor are just dead bugs that I can't see in heating element burning up.
It been only running for an hour now and it cooling down inside the refer but I notice it draining the battery quite fast requiring me to use charger to keep it stable,
Is that normal for it to drain so fast when on 12 volt?
I need to replace the 110v to 12v converter since one in it is like a big old transformer and doesn't seem to be working.
Will the modern day converter be able to keep up with the current demand of the older model refers? It seem smaller when I looked at them at the RV salvage yard and they wanted a hundred a piece.
A photo with the refer out of the pop up camper and being tested on a 12 v battery attached to a charger.
Bill
Bill
