dougrainer
Nov 07, 2015Nomad
enblethen wrote:
Try to clarify filing of tanks.
The OPs profile does not specify what type of rig.
MHs have a permanently mounted tank and only needs to be shut off before filling.
Some fifth wheels have the tanks in the front compartment and are suppose to be removed to refill.
Travel trailers normally have their tanks mounted to the tongue areas in open air. They may need to be removed if filling stations requires it. Some do and some don't.
The ONLY SAFE way to fill DOT portable RV LP cylinders is by WEIGHT. That means they must be removed to correctly fill them. NOT filling by weight regardless of where they are is dangerous. ASME tanks on Motorhomes are filled with the tank in place. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
