MEXICOWANDERER
Nov 07, 2015Explorer
Because of expansion versus weight a scale is the ONLY way to get accuate measure of what went into the tank. Gas at 100F weighs a hell of a lot less per volume than gas at 32F
Most yard pumping personnel can't count past ten. Refer to government regs dealing with TEMPERATURE COMPENSATION for dispensers. Fill to the 15% level then quit. Some sloppy OPDs stop the music at 82%. Whaddya gonna do? I believe OPDs go to 40lbs and rare 50 lb tanks are exempt. Quicksilver had an 83 gal. Motorfuel tank.
Down here, OPDs do not fill and a Fast Fill fitting is the hot setup.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
