Dutch_12078
Nov 09, 2015Explorer III
aggiebob wrote:
Fickit= repair or fix it. These are removable r
Tanks 1 year old that are empty and need to be re-filled prior to my upcoming trip. I am trying to obtain if I have to remove them from my RV to get them re-filled or can I leave them affixed to said RV.. I thought this to be a pretty simple question, but, apparently, I don't know the correct phraseology needed to get the information I need.
There's basically no good answer to your question available here, since different refillers have different policies on the issue, and individual state and local laws may also differ. NFPA-58, the Liquefied Petroleum Gas Code adopted by most states as the basis for their own codes, does not appear to specify either way except in the case of those horizontal DOT cylinders that require filling in a vertical position, which usually requires dismounting them. The best answer for you would likely be to check with the LP dispensing station you intend to use and see what they require.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
