Old-Biscuit wrote:
. . . if thermistor is properly functioning........again WHY replace it. NO gain by replacing with the KIT.
Using an adjustable thermistor allows you to make the fridge colder because absorption fridges don't function well in hot weather.
I know this from personal experience.
I used
Dinosaur's Adjustable Thermistor (similar in principle to the
Snip The Tip) in my
Dometic NDR1292.
Old-Biscuit wrote:
BUT having a rheostat sensor will NOT affect overall fridge temps on models that have an adjustable temp control (on upper control panel).
It can affect (minor) those models that use a preset factory thermostat (non-adjustable models)
Again, not what I found. My NDR1292 had an upper panel with adjustable temp control.
After installing Dinosaur's Adjustable Thermistor (essentially in series with the fridge's thermistor), I was able to drop the temp by several degrees.
Have you actually tried either of these?
