Oasisbob wrote:
Well whle going to a residential unit is a cheap fix consider how it will effect your resale value? Also when traveling what then? How will you keep the door closed? You may already have these figured.
Worse case scenario these issues are all irrelevant as the residential fridge will increase the resale value and an inverter will keep it going when traveling. As to keeping the door closed that is a no brainer with several simple solutions. Any inconvenience is outweighed by the superior performance of the residential fridge vs the absorption fridge.
