kioticoachman's avatar
Aug 15, 2019
Refrigerant Fill Port
Dear Friends ... Can someone direct me to Where is the LP Refrigerant Fill Port on my 2001 Ford/Coachman - Catalina Sport E-350 Super Duty RV. Thank you very much! KK
  • kioticoachman wrote:
    Dutch_12078 wrote:
    Check the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
    I should have mentioned the place to add R-134 recharge. But you are correct the Low Pressure A/C port IS just above the engine battery. Fairly easy to add A/C Pro recharge if needed. Thanks for taking the time to help to locate the LP A/C Port.
    The first thing is to connect the hose and see what the pressure gauge reading is.
    Apologize for the misleading assumption. I really don't think I will have to replace the refrigeration/cooling unit at this time.:) Thanks again! KK
    Happy to help! :)
  • larry cad wrote:
    "LP" as in "low pressure", not "LP" as in "liquefied petroleum", the stuff in the tank that you use to cook food. Just a bit confusing.
    Well, I had to do a lot of reading on exactly what "LP refrigerant" is and I think it is "propane"... the same quality of stuff you cook with. It's flammable. Here's one of the better web sites with information on it about the differences, pros and cons of using this stuff. And by the way ... this was a new one for me too! I'd never heard of this before until the OP made this post.
    Click here.
  • "LP" as in "low pressure", not "LP" as in "liquefied petroleum", the stuff in the tank that you use to cook food. Just a bit confusing.
  • Check the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
  • Absorption refers do not have a refill port. When it leaks the cooling unit has to be replaced.
  • If I understand the questions, I don't believe there is a fill port for the refrigerant.
  • Refrigerant doesn’t “disappear.” Have you repaired the leak?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
