donn0128
Aug 05, 2017Explorer II
30 amps is a normal 110 outlet. It is simply wired using heavier duty wire. A standard household outlet while 120VAC not 110 VAC is 15 or 20 amps. If your blowing a breaker it means your drawing too much power. Reduce useage. Turn the converter off, be sure the water heater is off. Then, if its still tripping the breaker check the electric element on the refer. Possibly it is dieing.
