John___Angela
Aug 14, 2013Explorer
rfuerst911sc wrote:
Can I feed enough current to a residential type fridge with two 6 volt batteries like Trojan 105's ? I do have a Honda EU3000 generator but would like to add some amount of solar. Assuming a fridge of the size I'm needing draws 1 amp on 110 how large of an inverter allows some safety margin ? The only item that would be on the inverter would be the fridge.
Because of startup current involved with a compressor type fridge I recommmend a 1000 watt sine wave inverter properly installed. The two six volts batteries would be more than ample if they are dedicated to the fridge. I also recommend a 160 watt solar panel as an addition to whatever you already have. In fair weather conditions the single panel will be enough of a contribution to the system to offset the use of the fridge assuming normal duty cycles of the compressor.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
