Old-Biscuit
Apr 05, 2016Explorer III
lifeinthesnaillane wrote:Old-Biscuit wrote:
Thermocouple has to get HOT
When it gets HOT it signals that a flame is lit
That signal holds magnet up in safety valve allowing gas flow
What Brand/Model of fridge?
Sounds like a early Dometic (RM77 or earlier)???
Early Dometic Service Manual
Pg. 35 of interest
Wow thanks for the manual and page number. I'm not sure of the model #. I'm in mcdonalds using wifi. I'll check when i leave. Hopefully camping world has the thermocouple. I'm on the road in Utah. If I keep the button pressed by wedging a curtain rod between the gas button and a cabinet in order to keep the flame lit, is that dangerous?
It may or may not be thermocouple......could also be safety valve (magnet)
Yes it is dangerous to override the safety valve......if flame should go out propane will continue to flow and could fill camper BOOM!
IF.big IF
It is an early Dometic RM Model then your regular thermocouple will NOT work.........
Check with Dometic first for correct part number
You can order parts for your Dometic RV product(s) directly by calling the retail sales department at 1-800-544-4881. Please be sure to have your model number available so the correct parts list can be obtained.
Then Check with PPL RV Parts On-line catalog for parts
CLICK
Good luck
